Another use for tint tubes
That looks awesome. i have a 100 pixels here i am yet to use and that could well be a suitable use for them.
That is a great effect and shows there is no limit to the creativety of the members of this forum
Henedce
110 Wallace st
mick8248 said:
Great effect, how are they mounted?
I just cut the tube to length and capped each with acrylic sheet . They are glued to a piece of timber that was routed so everything stayed in place.
Sorry I dint take build photos as I was too keen to get this done :)
neilric99
Irvine, the OC, CA
great idea Henedce, another idea for getting the gutter line running with great RGB effects.
now you need to coin a name for them. how about pixitubes
damo1271
Adelaide
David_AVD said:
Did you have some automated help for the acrylic discs ?
When I need an acrylic disk I simply use a hole saw in the drill press. Take the centre drill bit out of the arbor and then you will get a nice round cut out with no hole in the centre. Tip: you need to measure the internal diameter of the hole saw, not the external! You MUST use a drill press if this is going to work and secure the acrylic tightly as there is no centre bit.
PS you will need to file the disc to tidy up the edges. This method isnt perfect!
