  1. grahami2006
    grahami2006 Full Time Elf
    Jan 19, 2012
    197
    0
    Bathurst NSW
    Can anyone give me an idea of the best place to buy cat5.
    Graham
  2. ShellNZ
    ShellNZ Senior Elf
    Jun 17, 2012
    868
    3
    Karaka, Auckland, NZ
    Honestly? I would buy the cable and tool and make them yourself, you will save oodles of money. I have.
  3. Jamie
    Jamie Lighting up the night.
    Dec 16, 2010
    399
    4
    Warwick
    I would say also make it, but if you need to buy it , any electrical supplier like rexel, haymans will sell made up lengths.malso if you know an electrician they could make them for you to length.
  4. OP
    OP
    grahami2006
    Jan 19, 2012
    197
    0
    Bathurst NSW
    Yes I can make it myself just looking for the cheapest place to buy cable without the RJ45's.
  5. BundyRoy
    BundyRoy Dedicated Elf
    Apr 9, 2014
    1,026
    9
    Depending on how much you need I would go here
    http://www.homewired.com.au/store/category/7/cat5e-cables
    or here
    http://www.electriciansupplies.com.au/shop/index.php?main_page=index&cPath=26_250
    Can always go to ebay as well
    Homewired is on ebay under aushomecabling. Last time it was cheaper to buy the stuff off ebay than their website. Have dealt with both companies and both very quick turn around. Electrian supplies is super quick. They also have a set $10 delivery rate which is good when ordering wire cable as it can get heavy in a hurry.
  6. AussieDoug
    AussieDoug Full Time Elf
    Dec 1, 2012
    375
    0
    I bought a couple of 15m patch leads from one of the reject / dollar shops for $16 last week.
  7. AAH
    3,148
    299
    Given a choice I will always buy the pre-made ones. If you get a good supplier they are relatively cheap and wiring up RJ45 connectors can be a major PITA. The fact that most RJ45 connectors are made for single strand cat5 cable rather than stranded also makes things more complicated. You should always try to use stranded rather than solid for your Xmas light stuff as the solid is designed for fixed installations and is more susceptible to breakage from winding them up or flexing them. I have a tool, connectors and cable ONLY for when I am in desperate need of a cable as I've ran out. That's my 2 cents worth anyway :)
    "About" $1 per metre is what you should be able to find cat 5 patch leads for and they are always stranded cable.
  8. OP
    OP
    grahami2006
    Jan 19, 2012
    197
    0
    Bathurst NSW
    Thanks Alan.
    What I need it for is to use between the Ray Wu controllers. I have one lead from the computer to the first controller but then need to make up leads with 3 pin plugs on them to link the other controllers. I had heaps last year but the better half decided to clean out my goodies box.
  9. fasteddy
    Apr 26, 2010
    6,637
    70
  10. djgra79
    djgra79 My name is Graham & I love flashing lights! Generous Elf
    Dec 27, 2011
    1,231
    377
    Cranbourne West
    I've also recently purchased from http://homewired.com.au/ as it turns out I live 5 mins drive away so have saved on postage too!
    Easy to deal with and very helpful with my questions around what my requirements were for home networking. Pretty competitive on prices I found (for pre-made if that is what you are after)
  11. AAH
    3,148
    299
    Aaaaargh at the use of the Cannon plugs. If you're using them then the price of the cat5 cable is fairly irrelevant. It's much cheaper and takes less space to mod the board by adding a pair of rj45 sockets. Some of the new 27ch boards have these sockets on them.
  12. multicast
    multicast Senior Elf
    Jul 13, 2013
    715
    8
    really? For the time and effort involved, and the low cost of Patch cables, is it really worth it?
  13. ShellNZ
    ShellNZ Senior Elf
    Jun 17, 2012
    868
    3
    Tis for me :) I can make them to the perfect length and I rather enjoy making cables :)
  14. BundyRoy
    Apr 9, 2014
    1,026
    9
    I'm not sure about the saving. I did make one. Two reasons. I needed a crossover cable for the DMX to LOR and wasn't convinced the "crossover" cables I could get off the shelf crossed over the right wires. They probably do but I have been caught several times with lights stuff already because my understanding was not good enough. I also had a box of cat 5e cable with at least 100m left in shed from when the network at my house was hard wired and I hate stuff sitting there being wasted.
    So I bit the bullet and bought some crimpers ($10 delivered to my door) and some rj45 plugs and made my own. Got to say it wasn't the most pleasant experience to start with. Then watched a youtube video on how to do it and it became a bit better. It does take a while (well for me anyway) to ensure you have the wires right.
    If I need more cat 5 cables I will probably continue to make my own until my supply runs out. Then I will have a decision to make but will probably go back to store bought.
  15. fasteddy
    Apr 26, 2010
    6,637
    70
    I would agree here, the time and effort needed to make your own compared to pre made really makes any savings insignificant
