It's all good Steve. Just trying to help make sure your project is as bulletproof as possible.
Was there a PEBKAC fault in typing that?Shorted MOSFETs are the most common failure mode. The other is PEKAC. Wire the other (wrong) way at your own peril.![]()
I'm not sure if Blue Point Engineering ships to Australia. Their website should have a contact link for questions. But have you exhausted an Australian search for a device? How about this?Thank you everyone for your input. My apologies if I have upset anyone. It’s impossible to know what people have done for a living or currently do and what they’re experience is when all you see is a ‘username’.
TerryK, does blue point engineering shop to Australia ? I like their 4 and 8ch relay board and their supporting document appears to explain their setup quite well. It even contains wiring diagram for communications and equipment.
Steve
It's all good Steve. Just trying to help make sure your project is as bulletproof as possible.![]()
I have seen that one. My circuit board soldering skills aren’t that flash though.I'm not sure if Blue Point Engineering ships to Australia. Their website should have a contact link for questions. But have you exhausted an Australian search for a device? How about this?
Do you a link to his products ?sorry if I'm misunderstanding but David Peace has a board that will operate servos and linear servos as pixels you just program them in xlights like you would a normal pixel is that not the same ? I know linear servos may be more expensive than actuators but not much more, from memory it will drive dimmable DC outputs as well as Servos from a WS2811 pixel line.
