Yagoona lights said:just a quick question kwick have you run the lorcommslistener.exe file.
as this needs to be done the first time for that dos window that david shows in the wiki page to work.
kwiksmart said:there are three lights DMX - stays on, MODE - flashes, +5 - stays on
David_AVD said:I know this was resolved in chat but for thread continuity;
As you have a LOR USB dongle, you need to connect to the LOR controllers first then to the APC745 wiring adapter then to the DC48.
[PC]--[LOR Adapter]--[LOR Controller]--[LOR Controller]--[APC745]--[DC48 Controller]
ryanschristmaslights said:That's true. the LOR/ESTA DMX adapters work both ways. However it just works out that David's example is most cost effective with only the one adapter required instead of two and in this case kwiksmart only has the one on hand![]()
ɟɐsʇǝppʎ said:If you bought 2 of the APC745 adaptors wouldnt that then allow you to use DMX first then LOR after just in case your layout is physically loacted in this way.
