DIY Coro Props
stooged
Pixelated
Bunbury
this will be a bit of a journey but i will be making videos which will show how to design and make props using lightburn, xlights etc.
the video i am posting here just shows how to use lightburn and my laser to make dual row pixel stakes but i will get around to showing how to make larger props and print them out onto paper to make templates so you can use traditional tools to cut the prop out.
i know props are not that expensive in this hobby but i love the "diy" aspect of it so as i create these things i will record them and share to hopefully empower other people to do the same.
View: https://www.youtube.com/watch?v=hySJ92fs_2o
Very nicely done. Loved that you showed quickly and easily how to map custom props in xLights. I knew that was there but didn't realize how easy it was to do. A little off topic but could you talk about your laser in general. I saw you had a NEJE Max 4 with the E80 in your videos. Is that what you used to make these with?
Very cool post! thanks for sharing!
If i get in to custom props, this will be a big time saver
Cheer!
It's good to see someone using the automatic pixel mapper in xLights!
I think it's an under rated feature of xLights, I don't see mention in the forums, Facebook groups or other videos on it being used very oftern.
The spinner was cut on the max 4 with e80 and the frame extension to increase the working area to 750 x 1030
The pixel stakes were cut on my max 3 with e40
That feature in xlights is awesome, i have mapped a few custom props with it.
It took a bit of experimenting with it at first to figure out the best way to record the prop but once i worked that out it pretty much nails it first time every time.
another one for the list which is a tune to sign made from hub75 panels, i was going to do a coro one but i think this type is better.
the laser cut files and info are here
https://github.com/DnG-Crafts/tuneto
Thank you so much for everything in this thread!! I'm new to the hobby and have a very niche idea in mind (santas sleigh being pulled by crocodiles 😂) and would love to build and map my own props for next year. These are great resources 🙌🏻🙌🏻🙌🏻🙌🏻
Maybe a silly question, but could you cut out coreflute props with a jigsaw?
Not really .. maybe with an ultra fine blade it might get a nice cut, but I did try a bunch of different ways to cut coro many years ago, most mechanical type cutting tools just leave really rough edges.
You can buy dedicated coro cutting tools - https://www.sawtrax.com/product/coro-claw-x-10-mm/ .. curves can be tricky though
