What's this about a file hash?
I'm pretty sure the others were just talking about the run time being the same.
If your differently sourced version of the song is truly identical, just give it a unique file name and tell xLights to use that instead.You can tell xLights to use a different MP3 after the sequence is created.in Xlights, when you go to File -> Sequence Settings, you'll see after the media item, a Hash. I'm assuming xlights will come up with some sort of issue when you render the sequence.
No going deep on it, #ash is an algorithm that triggers the algorithms like in YT for copyright strike when in music. they are like a digital signature but for data, serves as file path tracing. Another tracing tool...So the hash is just being used as a way to identify that the audio file used is (likely) the same as the one it was originally sequenced with?
