F4V3 Diff receiver in DMX port?
Discussion in 'Computers, Cabling & Other Miscellaneous Hardware' started by Verb75, Feb 17, 2018.
  1. Verb75
    Verb75 Apprentice Elf Generous Elf
    Dec 13, 2016
    68
    44
    Cairns, QLD
    I was going through the manual and came across this:
    3.2.2.2. Differential Receiver
    A single Falcon 4-port Differential Receiver (see Section 3.2.3.1.2) can be connected to the serial output port (also referred to as DMX Port). This allows for the Pixel Outputs to be placed up to 250’ from the F4v3 controller with a separate power supply.
    I thought you needed the Diff Expansion board to run the diff receiver on the F4V3?
  2. keithsw1111
    keithsw1111 Full Time Elf
    Oct 11, 2012
    452
    79
    Kellyville, NSW
    You can run one only directly off the board.
  3. darylc
    darylc 404 darylc not found Global Moderator Generous Elf
    Dec 8, 2012
    530
    132
    As far as I know, the F4v3 does not support a receiver board on the DMX port.
  4. OP
    OP
    Verb75
    Dec 13, 2016
    68
    44
    Cairns, QLD
    That is what I had thought too, but this was taken directly from the F4 manual. I did some more reading last night, and further along it said that it will only power the first port of the receiver. So its limited to 1024 pixels. (according the manual)
  5. darylc
    Dec 8, 2012
    530
    132
    yep that sounds right
