Henedce, where did you get the gorilla grip, I haven't been able to find it? Or does it have a different name in Oz?
The great thing about these tubes, it doesn't matter which way the lights face. If I get the tubes to arch the way I want, the lights will be facing up at the sky. The entire tubes glows all the way around with a slight dark area where the RGB strip if laying.dougd said:When using these tubes is the LED pointing directly to the front or are you turning the tube 90 degrees?
Henedce said:I used Gorrilla grip Cyo glue with a 1 inch off cut split down the middle and wrapped around the outer to give the glue something to hold onto .
I challenge you to find the join
Column Prototype
New Display test
