lithgowlights
- May 6, 2010
Graham, I fit a PSU, fuses and a Ray Wu 27 chan, or P12R in them with ease
Lanas kids lights said:Hi just wondering how big of a power board fits in these, as the closet masters is 4 hours way, so I thought I would ask other members what size power board fits in size one, thanks
anon said:Penguineer, what are you using for the mounting plate/panel?
I was looking at some 3-ply marine plywood which would work out quite cheap...otherwise was going to buy some cheapo chopping boards and cut them up. Nylon would be a bit easier to deal with when mounting with standoffs.
Robbo said:Penguineer:
are you attaching the boards directly to the ply or are you using a spacer of some sort?
penguineer said:Yes, definitely spacers at the back of the board. Just got a couple of packs from Jaycar, but you could probably do a decent job with some suitable length 3mm bolts and some plastic tubing.
Keeps the board off the ply, avoids possibility of complications from anything shorting across the timber/paint?(!!), looks a bit more professional and if a small amount of water does leak into the box the board itself won't be affected. At least, that's the theory......
Cheers!
ԆцряєсϮ said:I'm running 4 Ray 27's out of my boxes.
I bought some 5mm Teflon chopping boards from the $2 shop to use as backing boards.
I've slotted them to mount the boards horizontally.
Robbo said:ԆцряєсϮ said:I'm running 4 Ray 27's out of my boxes.
pictures not coming up for me for some reason ԆцряєсϮ but how are you getting 36 leads through the holes?
