foodi
3mm perspex 400x 600 x 4 and 1 400x400
Has any one daisy chained Moving heads ?? Does any one know why only the group model works. When I put things on each of the single Moving heads nothing happens ??FYI
Anyone thinking of using moving heads in their display, this video has some clever ways to set them up in layout and to sequence them:
youtube.com/watch?v=9AkyT_O7zvw&ab_channel=SwyperOrozco
Long video in which he also talks about and shows his weatherproof 350W moving head lights, and issues to be aware of if purchasing.
You dont have to group them like Swyper did, it's just an easy method to control them all at once.Has any one daisy chained Moving heads ?? Does any one know why only the group model works. When I put things on each of the single Moving heads nothing happens ??
Interesting video to watch View: https://www.youtube.com/watch?v=9AkyT_O7zvwFYI
So how do you deal with the heat generated by the lamp in these ?
Thanks, that's what I was thinking of too. The heat has to be removed somehow, or the moving head would just cook itself from the 230w/350w lamp that is always on.The professional weatherproof domes have fans and vents in them. eg https://magicallightshows.com/collections/products/products/moving-head-outdoor-enclosure
if it helps you make the decision, you can even get scented fog juice for your fobble machine.I figured that sequencing them is going to be a huge job.
Thinking of a snow machine to run down the front, but those fog/bubble machines sound interesting too.
Now that sounds interesting. What sort of scents do they have ?if it helps you make the decision, you can even get scented fog juice for your fobble machine.
