Slite
AussiePhil said:swfraserau said:I have access to a supply of these a work. I had actually grabbed one a few weeks ago with the idea of putting lights into it just like this (though I didn't have any idea about what could actually be done with RGB stuff back then). I will have a look tomorrow to see what is left there.
On a side note I have a question. Has anyone done anything like using 90mm stormwater pipe cut in half, with a strip of Corro over the front? I would like to do this for the veranda posts of our house,which are about 5m high, and I would like a softer, diffused look, rather than a thin line of pixels.
Now there's an idea.....
I believe that dmoore did something similar but only using coro and from memory it looked quite good.
Phil
Yeah, I think he just did rounded coro (I guess just slit it between the flutes and bent it???) and placed over strip, at least thats what it looks like on his behind the scenes video.
As for cutting 90mm pipe in half and using coro too difuse...sounds good, BUT... how would you hold the pipe in place? Wouldnt it be easier to find square plastic tubing and cut in half? Would work nicely to difuse with coro and also just drill some holes in the "back" wall of the tubing and then just use deck-screws to fasten the tubing to the posts? Or, you could hot glue plastic tiewrap holders to the back of the tubing and tiewrap them in place I guess.
