Roosta said:My 10 psus dont create much noise from the fans.. They just click on and off and create a small humm that you can only notice in the garage..
I cant immagine yours will be any different buddy..
It will once my electrician comes and installs a power point for me. It will into the rcd units at the bottom with 4 power supplies of one rcd each and power board running of 1 rcd.djgra79 said:So does all this run off one 240v input plug??
Fasteddy said:Just be aware that running lots power supplies (especially the cheap Chinese ones) on one circuit with an RCD may create nuisance tripping as DC power supplies inherently leak a little current with the cheaper ones letting out a little bit more, this accumulated earth leakage may be high enough to trip the main circuit RCD.
Also consider the inrush current when this is powered on as all the power supplies will start at the same time which may trip the CB
In most cases this shouldn't be an issue but it can be especially when you have many DC power supplies connected to the same circuit so always good to be aware of the possibility of this happening.
Roosta said:Hey bud,
Nah no trips at all.. oh actually yes in initial setup i did, however it was due to using too long screws on one PSU which was shorting and tripping the one rcd... so did its job..
In rush and too many supplies were no problem..
Mine is fed by a 15amp outlet on its own feed, and max current draw hile running the show peaked at about 800w @240v, which is <4amps....
Cheers,
Kimbo3000 said:
back to the colour schemes.. the way i remember it is:
Earth = green/yellow (always)
Active -> you touch it.. you poo yourself (ie brown)
Neutral = the only one left (blue)
Also, how do you's manage to use soo many psu's in one location? is it for house outlines etc? What size cables do you run to the pixels for power? (low voltage)
Noel Richards said:Fasteddy said:Just be aware that running lots power supplies (especially the cheap Chinese ones) on one circuit with an RCD may create nuisance tripping as DC power supplies inherently leak a little current with the cheaper ones letting out a little bit more, this accumulated earth leakage may be high enough to trip the main circuit RCD.
Fasteddy what I understand you are better to have them through a switched powerboard so you turn either each or say 2 at a time on so it stops the the voltage drop that causes the RCD to cut out.
You are one of the lucky ones, having a dedicated feed for your display.Roosta said:Hey bud,
Cheers,
Kimbo3000 said:Also, how do you's manage to use soo many psu's in one location? is it for house outlines etc? What size cables do you run to the pixels for power? (low voltage)
scamper said:You are one of the lucky ones, having a dedicated feed for your display.
In reality most of us run our lights off power points close to where we need them.
I have done some testing this last few weeks, as last year I did trip my cct breakers a couple of times at switch on, It turns out the power point I ran 5 of my power supplies off was the same circuit that ran the kitchen, ie. fridge, freezer etc. so when they were running at start up it tripped. I have found that I can connect to another circuit that is hardly used, so will change to that.
The moral of the story is, spread the load and you should be fine.
