Australian version on the colors
OK, I'm not aware of any Australia standard using black and white for active and neutral.
David_AVD said:Australian version on the colors
Charl Marais said:Prof, you are indeed correct.
Black is live or active or phase.
White is neutral.
Green is earth or ground.
https://www.allaboutcircuits.com/textbook/reference/chpt-2/wiring-color-codes-infographic/
Regards and be safe.
Fasteddy said:I think this thread needs a little warning about non qualified people working on mains voltage :
Electrical work on mains voltage done by non qualified electricians is an offense in Australia and if something was to happen then you will be liable and doubt any insurance claims would be paid.
So please be careful if you decide to work on any mains systems which includes simple tasks like adding a power cord to a power supply because effectively you are breaking the law. I think the US is a bit more relaxed on this as their voltage is 110volt compared to 240v which dramatically increases the chance of fatality if you get a shock
If you do choose to do your own work make sure it complies with regulations and also ensure you have this connected to an RCD protected circuit and preferably have an electrician take a look to ensure its safe and complies
Remember you cant see, smell or hear electricity, but you sure can feel it
the grinch said:Yes totally agree with eddy . For safety reasons needs to be wired to Australian standards ! Although you may understand your wiring configuration cd man others may not and for some unknowingly person may work on your panel for whatever reason and could cause fire injury or even death ! Plus also I think in the long run you will end up confusing yourself I feel is always a good practice to stick with Australian standard wire colors even for low voltage wiil definetly make things simpler and easier for fault finding etc plus less chance of blowing stuff up . Thats great you have an electrician to help and I hope he agrees also I reckon he should . But yes if uncertainty with 240v don't touch always ask for help from qualified person . Good luck mate and great your asking advice
