New xModel Design App: Aussie Pixel Studio (browser-based xModel editor)
BooY
Topper Man
Jimboomba
Intro
Hi everyone, I’ve been working on a new browser-based xModel design app called Aussie Pixel Studio and wanted to share it here. It’s meant to make pixel prop layout and wiring visualization easier, especially for folks who want a more visual CAD-style workflow than the usual spreadsheet/grid-based xModel editors.
What it is
Aussie Pixel Studio aims to be a lightweight web app for designing xModel pixel props. It focuses on:
  • visual node placement
  • wire/connectivity layout –(only basic at the moment)
  • xModel import/export compatibility
The goal is to feel more like a vector/CAD Designer than a spreadsheet editor / grid based editor.
How it works
  1. Open the app in your browser
  2. Import a background image or several as reference
  3. Import an existing .xmodel file to modify or start a new prop design
  4. Use the canvas tools to place pixels/nodes and draw pathing
  5. Use the Pattern tools to lay down nodes across the drawn paths etc
  6. Adjust spacing, node order, and visual layout
  7. Export the finished design back to .xmodel
It also supports importing SVG backdrops so you can trace outlines or existing prop shapes while you design.
What’s working now
  • Core visual layout and editing
  • Pixel node placement
  • Node Spacing both too close and to far warnings (adjustable)
  • Wiring / connection visualization including warnings for wiring jump maybe required (default is 60mm)
  • Faces / States / Sub Models with visualization and default colours where xLights allows it
  • Milestone Nodes – adjustable highlight Nodes every ## for wiring/counting when pushing
  • Zoom, pan, and selection tools
  • Backdrop import flow
  • Visualization of the cut holes off pre-defined bullet pixel hole
  • xModel Export, which tries to minimise the xLights grid size required to maintain design details
  • Ability to save model, and update later as a Rev up vs just overriding completely
What is still “in progress”
Some features are currently locked as work-in-progress while I decide the best user-facing workflow. That means:
  • advanced tools are visible but not yet fully functional
  • Multiple node templates to possible swap to seeds/other pixel shapes
  • the UI for some workflows is still being finalized
  • I’m still deciding how to expose certain options without making the app too complex
  • Wiring Currently takes the shorted path, which means on some alternating node patterns the wiring is overlapped.
So if you see a feature marked locked or “in progress,” it’s not ready yet.
What I’m looking for
Feedback would be especially helpful on:
  • whether this feels easier than existing xModel editors
  • any bugs, issues found.
  • any must-have workflow for common prop types
Final note
This is an early app, but it’s already usable for basic designs and xModel export. I’m iterating on the locked features and would love input from the community for anything I've missed, or lacking.
Link
https://aussiepropstudio.daveshotit.com/
Screenshots
I have "broken" the app already :D
I went to edit a custom prop that I have been working on and which I saved a copy of a few days ago. When I went to edit this prop to have a play with it via your app I got an error which I pasted a screenshot of below. I know it's a custom model as @Bernie_H and I created the model and submodels. When I opened the xmodel I noticed that instead of the CustomModel that the app appears to be looking for there was an "exported". I could probably just edit the xmodel with Notepad++ and get it going but it'd be nice if that model type was allowed.
I'd dearly love a video of the app in use as a heads up as I'd be keen to use it and have some idea of what I'm doing.
Hey Al,
Give it a try now, i didn't realise xlights updated the custom model, i've run an update and it should accept the newer style now.
Prolly added a few more bugs in in the process but should open
