P-DMX Controller For RGB Pixel Spinner
I really liked the RGB spinners that Bevo and kool-lites posted about. I was thinking that it would be nice to make an 8 spoke one using 6803 (digital) RGB strip.
To make construction and wiring easier, an 8 output controller could be housed in the centre hub section. Whilst a PIXAD8 would work, it's a bit of an overkill for only a few channels per spoke.
For example, 500mm spokes would only be 5 pixels (15 channels) each, for a total of only 120 channels. 5 pixels (15 RGB LEDs) spokes would allow "ring" effects (grow / shrink) in addition to the "spin" effects used with non-digital strip versions.
The required 4m (8 x 500mm) of digital strip could be cut from a single 5m length, with left over for replacement spares. You could also get 8 x 600mm (6 pixels / 18 LEDs) out of a 5m strip with just 200mm left over.
I think a P-DMX -> 8x SPI board could be done that has on-board 12V regulator for the 6803 strip and a 5V regulator for the micro, etc. A 3A regulator for the 12V should suit the 500mm (2.4A) or 600mm (2.88A) spoke versions. I'd probably use the "round robin" method of sending the data to the 8 pixel outputs. This would normally be a stretch for 8 outputs, but as there are only 120 (or 144) channels to distribute, I think it will be fine.
Anyway, I thought I'd put the idea out there. I realise that it's getting close for this Christmas, but it may interest people for next year. Never hurts to throw ideas around any time of year! :)
SmartAlecLights
Murray Bridge, S.A.
that sounds to me more like the firework type lighting where they burst from the center to the tips. does sound like a good idea, but more for 2012 at this late time
Yes, you could do a fireworks effect too. Using pixel strip is more expensive than regular DC strip, but I think there's room for both types in the fun world of Christmas.
Bevo
Let your Light Shine before men
Caboolture QLD
Great idea David.
I am hoping to get into some pixel strip next year. I cant wait to see what else other people are coming up with this year.
Haven't started the board design yet. Maybe this weekend in time for for next week's prototype PCB run.
Was thinking of using the same 4 pin pixel connectors as I used on the APC718 and Ed used on the PIXAD8. Also just a single fuse / polyswitch for over current protection as each output will only be driving less than 400mA worth of strip each. Will also have a DIP switch for easy addressing, a pair of RJ45 connectors for P-DMX and a separate DC input as well.
Not sure on PCB size yet. Will have to see how much room the output connectors and 12V regulator chew up. Hopefully small enough to fit inside the centre hub piece of the spinner.
I had another display idea for a board like this. Same hardware, different firmware.
Each of the 8 outputs could drive a column of 5 or 6 LED modules / pixels. The 8 columns would make a spectrum analyser display (vertical bar graph) like you see on some car / home stereo units.
To make it simple to sequence, just one DMX channel would be used for each output. Each channel would split into 5 or 6 level ranges with increasing level values lighting up more of the vertical bar, like a VU meter.
Another DMX channel could perhaps select the overall bar colours, or select a mode where the lower modules are always green, the 2nd highest is yellow and the top is red.
Anyway, just thought I'd throw the idea out there while it was still fresh in my mind. :)
Mike
CLAP infected!
Rockingham, WA
David thats a great Idea. I looked into this for this year but using digital tube instead of strip.
You could also use it on the meteor lights too
As for the fireworks light. Im looking at doing 2 or 3 of them for next year. But I havent worked out the whole thing yet. But probably 6803 strip up the pole then RGB meteors sticking out of a center hub or something like that anyway.
Depending on the max channel count on this board I think it would work quite well
cenote
Suburbs of Philadelphia
Pottstown, PA USA
David, with steve, did anything happen? Would love to GET MY HANDS on this one, be great addition to fireworks
Timon
Tustin, Ca
I'd like to see support for the TLS3001 and the CYT3005, same protocol, strings and strips. These are 12 bit but when driven from 8 bit source using a gamma of 2 they have a much better dimming curve than 2801's.
I guess I don't understand why the 6803 is so popular and gets so much support being it's only a 5 bits vrs 8 for the 2801.
The 6803 has been more popular in the strip because it was $20 cheaper than the 2801 strip and was very similar to the CCR and 12vdc is better to use than 5vdc. Otherwise if the cost of the 2801 was similar and in 12vdc then that would be the better choice. Ray now has 2801 strip that is similar to the 6803 with 2 extra pixels per metre and is 12vdc for $66 so the price is now very competative. But at the same time the 6803 has now gone down to $59. So the 2801 strip will be my choice for 2012 as its now great value and is 12vdc
For many including myself, the price is an important factor and its only being used for christmas lighting and not for video signage so issues like lack of dimming steps and less colours really doesnt make the top of the list when selecting and in reality the extra cost can be hard to justify when the audience watching the display will never tell the difference.
This is the main reason that people use the 2801 for the strings as the cost difference was never that much so it mades good financial sense to purchase those insetad of the 6803 when it came to strings.
