PPOE
mike395
Noob here... Hello All
I received my ECG-D2 today with intentions of utilizing a POE switch that have lying around. So I finally tracked down the jumper setting, and set the jumpers. Problem is I have no power. Can I get some clarification on PPOE vs POE.
Thanks in advance
I'm pretty sure you can't use a standard POE switch with Ed's boards. The voltage will be too high I think we were told.
harrisonk
Gold Coast, Australia
Eds boards use PASSIVE Power over Ethernet. These can be found on eBay for about $5.00. They come in either cable pairs or a junction box style.
BradsXmasLights
WiFi Interactive
Brisbane, Australia
Proper 802.3af/at POE has sensing to detect that a POE device is actually conencted before the 48VDC is supplied.
However I have found that a proper PoE powered device will still power up if you just put raw 48VDC on the pins (without any sensing done at the poe injector end)
I just run my D2 from a 5VDC plugpack.
mike395
Thanks for the response. Ive been using POE for quit some time and never realized there were two types. I do now though.
Thanks again,
Mike
