Ray's 10w and 30w DMX Flood Lights, and programming using DMX Writer "AT3031"
Kane said:
Which connectors? None of the 14 I got had any connectors. (next time, I'd probably ask for them though!)
I assumed (perhaps incorrectly) that he was talking about the little white connector that plugs into the back end of the programmer.
kane
jediknight2 said:
I was David...not there
Aha, I see.
I'm pretty sure I had a spare connector with mine, but just went and looked, and it seems as though I've lost it, otherwise I could have sent it over to you
I had a total of 4 connectors - two cables with a connector on each end - and am only using one, so would have had 3 spares
jediknight2
North Carolina
Also...the OP sais to connect the ground wire...from what I have seen...nobody uses the ground wire that is with the DMX+ and DMX- wires...they just use the DMX signal...is that not correct
Superman
Ipswich-QLD
Some people don't use the GND wire and have no issues. Just don't ask whats wrong when you don't use it and have issues. :) we have seen enough of that over the past week.
jediknight2
North Carolina
i am using a holiday coro usb dmx dongl for my two rgb floods.since it uses pins one and two for data...anyone know what pin is ground on that dongle...
Superman
Ipswich-QLD
I'm not familiar with the dongle, nor have I seen one. but if it has a RJ45 output and it has a ground connected in it, it should be on pin 7
I would expect that this info should be on the holiday coro website. David Moore has always been great with documentation
jediknight2
North Carolina
Well..the answer I got back from David was....the programer/dmx dongle wasn't meant to be used for pushing DMX....bought an Enttec and now I can run 170 Ray Wu floods!
