Ray's Pixicles
logandc99
The pixicles from Ray have arrived[emoji3]
Now it's time to have a play.
AussieDoug
Always good when they turn up on a day when you can play with them. Much better then turning up middle of the work week when you have no time.
logandc99
That's for sure [emoji3]
Short video of them working. Sorry about the video but it was a quick sling up in the roof and get them going
https://vimeo.com/131385053
logandc99
http://www.aliexpress.com/item/individually-LED-full-color-Icicles-string-DC12V-WS2811-controlled-all-white-wire-IP68-60nodes-set/32310871722.html
I'll measure them also
logandc99
There is a 2m lead to first drop. Then distance from 1st to last drop is 2.65m. (2.7m if you really stretch the thing). Comes with plugs at each end.
Kitman
Munno Para
I need these in my life lol exactly what I want to use to replace my existing icicles. It says he can make custom sizes, might have to work out what the maximum length a string could be before voltage becomes an issue and of course before the output of a controller reaches it's maximum and then order some, If of course I am allowed to lol.
arw01
Eastern Washington
I am hoping to go 42 feet myself and backfeed them 12v, I can do that now with a 30leds a meter strip and with the 12v back feed it's good to go.
Kitman
Munno Para
I am guessing that you are back feeding with the same power supply that you are using from the main feed, must be using some nice gauge wires to back feed at 42 feet.
I was thinking of keeping it a little more simple at the moment I have 4 strings of 5 meter icicles with 250 LED's per string if I was to divide each string in half and have pixicles made up that match my icicles and run 1 controller between 2 pixicles one string running left from the controller and the other running right from the controller I shouldn't need to back feed power (fingers crossed) then I would need 4 small controllers and power supplies to run it all and keep it neat.
Might work still need to do some more maths rough in my head at the moment hahaha.
richardd
Geraldton
I like the light and need to replace my icicles. I was thinking and want to know your thoughts of the following pattern.
345 345 345 345 345 345 345 = 84 nodes 2 strings would make one universes Do you think at 12 volts I can get across all 84 nodes without power injection or would be be better to have them as 4 strings 2 345 345 345 345 and 2 345 345 345 so I can inject between each string.
logandc99
Maybe I have misunderstood your question but I easily run 100 nodes off 12v without power injection for mini trees. I only power inject at the end now because I have my stars on the top of the trees and the power is not quite enough for those. However I don't use White a lot for long and don't get too worried about a slight variation in white at the ends of the 100 nodes. I would've thought 84 nodes would be fine.
This picture is two sets of the pixicles connected together with no extra power injection. That's 120 nodes.
madmaxisback
Malaga
Thanks for the info on these guys! I am getting some to test for next year so I will let you know how they go in the Perth heat! Cheers
starzen
Stuart, Florida
i am planning on getting pixel icicles for next year as well
i was wondering about the sequencing.
Would be a lot easier to order them with the same number pixels on each drop? So you can simply make a horizontal matrix?
ChristmasInKaralee
Karalee
I would think that you could do a lot more then 120 nodes before injecting power as icicles positive and negitive run across the top and therefor each drop is technically getting injected. I have mine in strips but haven't connected up and done testing but I was thinking I should get up to 300 nodes, as long as the power supply has the current to supply. 300 node icicle is still less distance then a 100 node string.
