Without any power distribution etc on it - modular, to plug onto a board for the form factor of what you're controllingA Baldrick8 with 2 ports eh? Theres an idea.
Yes it will work, and i've done something similar for my garage matrix.Just thinking about how I can minimise the cabling as 32 Xconnect 3 metre cables running to the F16 is pretty messy and seems to be heavy for my door which struggles to open. So can someone check this plan for me for me to see if it works?
1200 watts 12v PSU -> 5Amp inline fuse -> f16v4 with 1 expansion board -> data out only using 4 X Cat6 cables. Each cable supports 8 seed strings (32 total)
From PSU 8AWG to a 8 way terminal block with BUS Bar ->4.58mm twin core to 4 x F8 distro boards -> seed pixels
If this makes sense, then I will just have 1 8AWG cable running from the enclosure and 4 Cat 6 cables which drops down the cabling quite a bit (if my plan is sensible).
