- Thread starter
- #1
I found some little DC-DC stepdown regulator boards on AliExpress a few months ago. They use an LM2596 switching regulator and provide up to 3 Amps depending on the model. The ones I got were about USD $20 for 5 pieces delivered.
Another ACL member found a similar item on eBay. There are a heap of variants, but if you search for LM2596, you should find them easily enough.
Others have bought larger (higher current) versions that appear to be potted (epoxied) into a metal case / heatsink.
These boards could be used in display elements, dropping some common supply voltage (24V DC for example) down to whatever the item needs.
I encourage other members to post about the ones they've found and used in their displays.
