They look like you can just reverse the fan body which would then reverse the flow, would that be right, David!?!?
That should be fine. As far as I know there is enough clearance to mount the fan either way.
This is correct... I found with mine that the vent which was pushing needed the slats cut out to stop the fan air bouncing off it and coming back in. Made the push much better.They look like you can just reverse the fan body which would then reverse the flow, would that be right, David!?!?
All sticker come offThanks Bryan for the heads up about the boxes.
I have been looking online etc for a suitable cost effective box.
I have ordered some.
I hope the "Ammo Crate" is just a sticker on the front I can just peel off as my neighbours will probably freak out if they think I have ammo stashed around the front yard!
Yes I use some fly screen glued to the inside of all my vents to stop bugs/spiders getting in. You'd hate to fry a controller and/or PSU because of a creepy crawly for the sake of a couple square cm of fly screen!Thanx MacArthur, good to know.
Has anyone had issues with 'Creepy-Crawlys' in this control boxes?
We get seasonal mice, and subsequent snakes and they'd fit in thru those vents... Have been pondering the use of fly-screen to cover the opening.
Also, for storage, it may turn into a Cockroach 'Villa' if they have free reign...
I am about to order another 2.. It was a nice find...Thanks Bryan for the heads up about the boxes.
Heard back from the supplier.... here is what they said
The boxes were being used for packing.
The sales now exceed the ability to offset the cost as before.
Freight company charges these cubically so the freight is affecting the cost."
