String Flickering / not lighting Issues
I'm not sure how xLights would affect the flickering since you are running the test local.
The color change is very likely a misconfiguration (off by one or two). On the baldrick are they one channel bank or is each panel a separate set of channels?
Assume these are resistor pixels (not regulated)...Your voltage at the start of the string is already marginal. Did you try measuring it with only one panel connected.
6.2v on a 12v pixel is going to be unusable.
If I counted right, there 109 pixels in each panel. You could inject between panels 2 and 3 and between 4 and 5 and get much better voltage consistency. Make sure you tie the controller V- (aka ground) to the power injection V- on the power injection.
hey Gooliez, if you can go to baldrickboard.com/buddy and download the app, it will let you know if things are a little wonky and if it doesn't help then whilst it's flickering then you have the ability to send us a triage ticket from the app which will scan all the data and give us an idea of how best to guide you.
ok after 36 hours of nonstop heaviest tasmanian raid we've had this year, I can do more testing.
IF i do a test via the IP address, Star Flickers.
1st Video - Counting out the brightness levels
2nd Video- same again. just all the same. recorded only 40% but all up to 100 the same.
Installed balrick buddy. did a test pattern, and it cycles the 3 colours fine.
3rd Video - Baldrick buddy. Test Pattern fine.
Both tests were tested at 100% also.
screen shots of setup.
Sequence test video- not meant to be lit apart from a couple of flashes
Have you got your FPP instance stopped whilst doing the xLights test? If you're sending data twice to a controller (from two different sources) then it'll alternate between them.
yeah, I make sure it's all closed down before starting a new test each time.
I even power cycle the board to make sure there's no left over data from previous testing.
