I really like your 90mm pipe idea - I know I'd be doing exactly that if I was to ever build.indudio said:I am actually making these for permanent installation. Our new house starts getting built next week. In the front yard I will be running 90mm drainage PVC throughout the front yard underground to breakout points. This will connect directly into the garage where all controllers will be housed. Longest cable run will 20m.
I Will have heads and tails for this, so I can place caps over the PVC pipe and leave multicores in there.
I was looking at the security core wire, but I would need 6 lengths each of the 6 core to make 1 multicore for the ray wu board. Seeing as I am most likely to have around 15 of these controllers this year, that would be minimum of 1000 meters. As opposed to only needing about about 800 meters or so of the other cable.
However, I do want to set this up right - would solid core installed permantly be ok? Or should I go just go with the security cable ?
indudio said:In the front yard I will be running 90mm drainage PVC throughout the front yard underground to breakout points.
