Virtual Santa.
Discussion in 'The Family Room' started by mellowcouple, Oct 30, 2017.
  1. mellowcouple
    mellowcouple Full Time Elf
    Dec 18, 2011
    284
    15
    Whyalla
    Hi guy's, can anyone recommend a projector around $300 that would be good enough to display a virtual santa. There are so many different projectors out there and it's way to confusing.......lol. $300 is my limit so hopefully there is something that will be ok to use.
  2. Wendys
    Wendys New Elf
    Dec 27, 2016
    35
    24
    Wagga Wagga
    I purchased one off gum tree for the exact purpose,
    Its a bit old and big but does the job fine, SONY VPL- FX30
    it cost me ABOUT $340 delivered
  3. hardcore_rm
    hardcore_rm New Elf Generous Elf
    Jun 12, 2016
    24
    2
    australia
    U should only need a basic data projector if all you are using it for is Virtual Santa. I cant comment on models around that price range but I have been lucky enough to pick up an Epson TW4500 for $199 and a Benq for $29 from cash converters. both work fine and look the same for the non HD Virtual Santa. Might be worth checking out second hand stores for cheap one if that's your only purpose.
  4. scamper
    scamper Senior Elf
    Jan 5, 2014
    845
    83
    collie
    Just be careful on old projectors. I used to repair them so this is from that experience.
    The older projectors have a lamp life. You MUST replace the lamp when it is due and not wait for it to blow as when they blow, they usually take out the power supply and sometimes for worse.
    So check the price of new lamps and also check the lamp life, they will almost always have the info in the menu.
    For a virtual santa, I bought a cheap projector a few years back and it does the job fantastically.
    You only need a small resolution if that is all you want it for as you don't want it bigger than real life in your window or it will look silly :thumbsup:
  5. David_AVD
    David_AVD Bite my shiny metal ass! Generous Elf
    Jun 12, 2010
    3,597
    96
    They were bargains. The Epson was a very expensive model new.
  6. djgra79
    djgra79 Senior Elf Generous Elf
    Dec 27, 2011
    871
    159
    Cranbourne West
  7. keithsw1111
    keithsw1111 Full Time Elf
    Oct 11, 2012
    342
    42
    Kellyville, NSW
    I got a 5000 Chinese lumen one from Ali express. About $250 usd. Very very bright.
