Mike
CLAP infected!
sounds like I have a new project for next year David they have the standard adapters but i dont know if they can be retrofitted as such to DMX control
Mike... If those are 8 x 5mm leds spread over 32.5 cm wouldn't the gaps between them be around 7 times the width of the led? I'd check the dimensions of this gear carefully...Mike said:My idea is to interface DMX control with this
They are joinable and have 64 LEDs in them. size is 33cm
Normally thay have some kind of VGA adapter card jobbie with them which is controlled by an SD card or has a live video feed into them.
They are quite cheap at around $150- $200 per square meter so you could build one quite large for say $500.
What I cant really figure out is the protocals they use or if there is a DMX enabled one around.
What I did find was that they use a 74HC595N IC
Input volage:5V
Color: RGB
LED Qty.:576 pcs 5mm LED Per Square meter
and they have a PU cover.
