Derf
am now a 5v hypocrite
Can I make RF suggestions or do you want to stay away from that sort of stuff?
might seem insignificant as this would only be useful if using older dumb leds , but personally I'd like to see a fuse board micro ato fuses that plug into either for example Alan's 2811DC boards etc etc or Ray's 27 Channel as the only other choice is using wires to jumper to each fuse and usually using either large automotive type fuse blocks or messy inline fuses
a small as possible board something like this
with this pin sort of thing solder to the input of the fuses so all that has to be done is unscrew all the connectors on the original board lineup the pins slide it in and screw them back up
hope this makes sense , as to how many people would want them I don't know what sort of cost they would be to manufacture is also a consideration
yes Alan that's what I'm talking about , not sure how much you mean it would cost for a board like this but it would make everything so much easier and more tidy I'm surprised that all these dc boards aren't fused , I like to fuse everything others don't which is why I think an add on board would be an option the pins should be set so the bord just slides into the existing screw terminals and do up the screwsAre you talking about a board that connects directly to the outputs of dumb rgb boards and has 1 fuse for each positive common?
If thats what you're talking about then it's not hard to do but overall it's likely to double the cost per channel at least when adding external to a dc dimmer.
PC power supplies dating back years ago used to regulate the 5V and the 12V was semi unregulated. It would go up and down somewhat depending on the load of the supply. It was also a requirement that there was some load on the 5V rail. This may have changed in the many years that ATC power supplies have been around. The biggest issue for using them is that they are primarily designed for a fairly constant load. When connected to blinky lights the load can vary from almost nothing to full load at the 20Hz update rate of the sequencer/FPP. The load variation depends entirely on how you sequence and whether you do step changes from black to white across a lot of your display or just the props connected to a given power supply.I suggest stuff which can be used with range of Pi stuff from the mico Pi to the Pi3.
I think people have said PC power supplies are no good for Christmas lights, never really understood why. Still have not see a good Pi hat to control a PC power supply.
Alan, how about an input hat for the pi/fpp? An interface to connect a number of physical triggers (buttons, switches, sensors, etc) to trigger events or sequences within fpp. I know the software is capable of this but what hardware would be required? How many physical connections could there be? Would this be limited by the number of free gpio pins? If you were to allow for pins already used for power, WS28xx, DMX etc how many connections are free on the pi?David_AVD and I were having a chat earlier about what else we could build to supply the blinky community. We both make and sell a fair range of stuff and neither of use came up with anything to set the blinky world on fire so I'm throwing it out to the community to offer suggestions on what could be built or what is needed.
