jimcllc
If I take 2 sections of 16ga wire, Lay them side by side(not end to end) and wire the ends together will I then be making a gauge thicker to minimize voltage drop for power injection?
mararunr said:So the joining at multiple points is what I must have been missing in my display this year. I just ran the whole length and only joined at each end. Did get some unexpected results. What would be the longest you would recommend going before joining together and then moving on?
Fasteddy said:mararunr said:So the joining at multiple points is what I must have been missing in my display this year. I just ran the whole length and only joined at each end. Did get some unexpected results. What would be the longest you would recommend going before joining together and then moving on?
This depends on a few factors including the length of the cable and the guage of the cable, but a general rule is
50 lights with 5 volts strings
120 lights with 12v strings
Inject between each strip using 5v
Inject at the beginning of the 3rd strip but back inject into the second strip when using 12v
firebug said:Fasteddy said:mararunr said:So the joining at multiple points is what I must have been missing in my display this year. I just ran the whole length and only joined at each end. Did get some unexpected results. What would be the longest you would recommend going before joining together and then moving on?
I think what mararunr is asking is involving the actual injection cables and not the strip. I too ran 6 core cable for the injection (using 3 and 3 twisted together), one of them being 14m long. Should I/we twist the wires together again at certain intervals along the wire or will each end be enough? I realise gauge and length are contributing factors but maybe just as a general rule? Or doesn't it make any difference??
Qiang Fu Kiwi said:Yes, but it will also potentially create other issues, you might get a lot of Common Mode noise. Your milage will vary, if you have to use two bits of wire, side by side.. Join them in several places along the line. not just at the ends.
Just dont join multiple wires for the data this will cause issuesmararunr said:Qiang Fu Kiwi said:Yes, but it will also potentially create other issues, you might get a lot of Common Mode noise. Your milage will vary, if you have to use two bits of wire, side by side.. Join them in several places along the line. not just at the ends.
So joining them in several places along the line has no effect? Sorry for dragging this on, just trying to learn.
Fing said:mararunr said:Qiang Fu Kiwi said:Yes, but it will also potentially create other issues, you might get a lot of Common Mode noise. Your milage will vary, if you have to use two bits of wire, side by side.. Join them in several places along the line. not just at the ends.
Hi,
I can't see any benefit to joining them in several places, other than to create work. It may be worth considering moving your power supplies closer and reducing the length of the DC run, and perhaps using multiple power supplies. But i digress, in answer to your original question, yes doubling the wires will double the current carrying capacity. Make sure you double both the +ve and -ve wires.
Fing
