Wiring harness???
pipersmall said:
Between the mid point and end point I would then assume that there will be unused wires left in the core?
Yes, I carefully cut into the cable at the mid points and fished out the wires I needed for those connections. Those wires in the latter sections are unused, but no real advantage in removing them even if I could.
It is an 18 core cable I got on special at Element14 (Farnell) about a year ago.
Each core is 7/0.2mm I think, so that's approx 24 AWG and good for about an Amp.
Just managed to pick up a 100 m roll of 12 core 7/.2mm from Dick Smith clearance for $25. Just walked in and made an offer as they are not stocking cable anymore.
Hey David,
In regards to the D Sub connector, when you say it is rated for 1 amp, is that per pin or for the whole plug combined?
Looking at making wiring harnesses for my big w lights to make things easier this year.
Also where did you get your cable from?
The 1A rating is per pin, so if any of the pins are a common wire, you'd need to take that into account.
I got my cable from Element14 (nee Farnell) when it was on a run-out super super special. That exact type is normally quite expensive.
