3D Printable 70cm 150 node star
Freman
Hi
My first Christmas design is a 3D printable 70 odd cm (it's like 73cm, or 69cm if you're measuring led distance) 150 node star.
With many thanks to @AussiePhil for testing iterations and encouraging me to increase the border thickness for rigidity. I present a thingiverse link.
Indigogyre
I look forward to trying to print one of these when the printer is dialed in.
rippernz
Good work..
I see that you have used PETG,
how hot do these yet?
Will PLA+ work?
AussiePhil
Administrator
Canberra, ACT, Australia
I took me a little while to work this out but here's how i'm going to set up the pixels.
This is going inside my larger 100 pixel star so the 30-50-70-100 progression works quite well in xlights, and i should be able to drive it all from one port
Won't know till some new pixels arrive
Freman
I took mine in the middle at the bottom (basically just as recommended by xlights), signal+power in one side, power injection in the other
EddieV
Interesting as i was thinking of something similar but cut on my laser cutter. Last year was the first time i brought any pixels and had a crack at making anything like this and routed one from MDF on my CNC router. It was to be mounted in an area with lots of protection so i wasn't concerned but this year i thought an upgrade to acrylic would be good which would mean it could be mounted where ever i wish. These end up 550xx490 roughly and take 144 Pixels
This is how my first one turned out and was looking for inspiration on how to improve on it
EddieV
Man, that looks great, what's to improve?
Mainly just making the backing from 2mm acrylic mostly so its weather proof i think. Looking around at other ideas for inspiration perhaps for some leaping arches and how to do the outline of the roof, walls and windows
