Hi
My first Christmas design is a 3D printable 70 odd cm (it's like 73cm, or 69cm if you're measuring led distance) 150 node star.
With many thanks to @AussiePhil for testing iterations and encouraging me to increase the border thickness for rigidity. I present a thingiverse link.
70cm, 3 ring, 150 led pixel star by fremnet
Printable tree topper for mega trees You will need: 1 x 3D Printer with a 300x300mm build plate 4 x M4X6X6 Threaded Inserts (Tho you could drill the holes all the way through and use 4 bolts 4 x M4 Bolts of sufficient length to mount 8 x zip ties, or 8 x m3/m2 nuts and bolts 150 x 12mm LED pixel...
www.thingiverse.com
