Push Button Speaker Box with Built in FM Receiver - As presented at the Perth 2023 Mini
Hi, is anyone able to help me troubleshoot, I think I had it all working last night, everything was lit up, I haven't plugged it into the speakers yet but when I pushed the button the timer started going and the green lights on the relays turned on. I was trying to adjust the time but now it still appears to count up but on the relays the red lights are always on but the green lights are never on. The design is as per the last one on this page.
Anyway of testing if the relays are working or not with a multimeter?
The display has P1.1 on it, then OP, and then 04.6. It appears to count up to 4.6, stop and then just goes back to 00.0. Not sure if I wired it up and stuffed the relays or the setting changed.
I found programming the hardest bit to figure out. Not to much risk in damaging the relay if hooked up correctly.
The biggest indicator is if you hear the 'click' when the relay is triggered. If its not triggering, its likely not programmed correctly.
Have a look at these instructions to see if it helps
Programming
Operating modes:
  • P1.1:signal is triggered again, invalid - Multiple pushes the button and it does nothing, ie timer from first push is length of activation
  • P1.2:signal is triggered again, the clock is reset - Each button push resets the timer from the beginning (i like this option)
  • P1.3 - P4 - Not used
Timing range
  • 0.1 seconds (min) to 999 minutes (max) continuously adjustable
  • How to choose the time range?
  • After setting the mode selection screen parameter value by a short press "STOP" button to select the time range;
  • XXX. decimal point in the unit place, time range: 1 second to 999 seconds.
    • 1. X a single dot point in second place, Timing range: 0.1 seconds to 99.9 seconds
    • 2. X. X. three dot point between all numbers, Timing range: 1 minute to 999 minutes.
  • For example, you want to set Operational time to 3.2 seconds, then move the decimal point to decade place, the digital display 03.2.
    • Other examples.
      • 15 seconds 15.0 (1 dot)
      • 15 minutes 1.5.0. (3 dots)
      • 5 minutes 0.5.0. (3 dots)
Programming
  • The module is powered up, the display at the current work mode (P1.1 default mode), then enter the main interface; press "SET" button for 2 seconds after release to enter mode selection interface; a short time by pressing "UP", "DOWN" key to select the mode (P1.1 ~ P-4).
  • Select the mode (such as P3.2), short press the "SET" button, then the parameter to be set flashes ( "OP" on-time, "CL" off time, "LOP" cycles ( "---" represents infinite loop)), by "UP", "DOWN" keys to adjust the parameter value, support long press (rapid increase or decrease) and short press (increase or decrease one unit); then short press the "STOP" key to select the decimal point position, select the time range (0.1 seconds to 999 minutes); short press the "sET" button to set the next parameters of the current mode of procedure is as above.
  • After the parameters are set, long press "SET" button for 2 seconds then release, the name of the current mode will flash once, and then return to the main screen, set the parameters of success!
  • The main interface: In the relay does not work status display "000" (no decimal point), with a decimal point under relay state.
  • Mode selection screen:Long press the "SET" key to enter, after setting is completed, long press the "SET" key to exit back to the main screen.
Great thanks for the guidance, I will keep playing tonight. Just to confirm, is it normal for the relays to have the red LED lit all the time, and then the green only when triggered?
Also, any idea how to reset the timer to default configuration? I couldn't find much from google.
For anyone reading this later and wondering, I managed to get it working again by changing it from mode 1.1 to 1.2. I actually prefer mode 1.2 (allows time to be restarted on button pressing) so I have left it.
Glad you got it sorted :)
After changing the delay timer to a 5V version, everything is working fine. Note that the blue board only operates at 6V or higher, while the red board also works at 5V. :)
where did you get the roo prop and that 'talk balloon' matrix from ? :)
They are both from Christmas Props Australia. I got Sam to do a bigger hole for me for the nose to fit the button.
Lots of messages on this thread! Trying to find the following info. Maybe someone can help me out.
I’ve made a push button system and works fine for the past two seasons. Not using the transmitter with the system. Using a direct cable from my pi. I’m looking to upgrade for next year by buying a higher quality amp. (My speakers are 150 watts) and also having a switch or something simple where I can bypass the push button and keep music playing. ( For when we are hanging outside)
Any recommendations on the amp and also a wiring diagram?
Thanks!
Here is a pic of my current set up. Trying to add a switch that allows me to use push button in one position and constant sound in the other. Anyone done this before?
What are you trying to do? Having it on in one position and on in the other position sounds like you can skip the relay and just have it on?
I’d like to add a switch (SPDT) to my set up that will allow me to bypass the whole push button system and just keep the speakers on. One position would do this and the other position would allow the push button to work. Thanks for any help or suggestions.
"Steve's push button music", as sold by bflightshows.com and Your Pixel Store, and which this thread appears to be a clone of, does incorporate the bypass switch which allows the music to stay on or activated by the switch.
Yep what @andrewa is suggesting is the right (and easiest) way to do it.
The relay on the board is just dry contacts, feeding the speaker through it and interrupting it. A switch that connects the two is all you need.
If yuou have two relay (for stereo) you just need a DPST (or DPDT) switch, with each position doing one channel.
Switch closed = Always On
Switch open = Automatic/Timer
As far as I can see the relay is not interrupting the speaker wire so you don’t need two relays. The relay interrupts the power to the audio amp.
@aimbrunone you could just buy an SPST switch and wire it between your power supply on the far left and the positive input of the amp module on the far right. This would bypass the timer when you want the speaker always on, and when the switch is off it would rely on the timer to supply power.
Just to be clear, see my piece of art below:
Indeed you are correct @Iain - I didnt look at the context. I have been toying with the idea of interrupting speakers instead of amp in my setup, to prevent delays and switch on/off thumps, so it was stuck in my head :)
