XLights to Falcon Player to BegalBone Black to Octoscroller P10 help
Latest update
When in Xlights and in Sequence page if I click on the matrix and expand all 16 strands then drop the butterfly effect onto strand 16 it works on that strand if I drop the effect onto strand 15 only 42 pixels light up (a shown in pictures above) if I drop an effect on any other strand nothing.
Don't know if this will help anyone
PS if I go to FPP and test the screens all pixels work ok, so the pixels/p10 boards are ok
If you go into xlights then tools>test>models and turn on and off nodes you may be able to work out what seems to be the issue. Turning on and off every tenth or so node will eventually show up where things are broken. From there it may be easier to work out how to fix it.
Update
I have got it working
Not 100% on how I did it, but I did change the settings from Multicast to Unicast with set IP address
My limited understanding (which is probably wrong) is when FPP is in bridge mode it acts as a through gateway and not a controller as Xlights is doing the controlling
